Why not!? Can you show the symbolic solution?
ValeryOchkov
I show to my sdudents the equations sin a + sin a = tan a
99% say that it is not correct? But 1%...
See please
8 REPLIES 8
nd what about Mathcad/MuPAD
Your text "sin(a)+sin(a)=tan(a)" shows different from you mathcad sheet picture.
Because it's more intrigueing I tried the latter first:
Note that there are four primary solutions to this problem. (see the float results). I expanded the smallest real solution up to 2 of 5 pages..
I guess the size is the reason why Prime will not give you the symbolic result...?
(To:LucMeekes)
In Mathcad 15 all symbolic results are equally wide ("only" three page widths). Using the modifier "simplify,max" the result gets four pages width.
OK!
What about the second "bug": 30deg+30deg+30deg=180deg?
@ValeryOchkov wrote:
OK!
What exactly do you expect?
OK!
See please https://en.wikipedia.org/wiki/Nikolai_Lobachevsky and Mathcad-sheet in attach
So I guess the picture you posted in your initial post does not show a bug or failure - it shows a hyperbolic triangle with three 30° angles (with a defect of pi/2).
The failure or bug is not the picture but your assumption that the angles would add up to 180° (which the angles in a hyperbolic triangle never do and which is not claimed in the picture) 😉
BTW, the picture is a stock picture and sells with different persons in different poses:
https://www.fotosearch.at/CSP992/k13871567/
https://www.meinekurse24.de/koln-nachhilfe-physik-mathematik-physik-mathe-nachhilfe-fur-schuler-und-studenten-611.html
https://de.123rf.com/photo_23371847_handsome-young-school-boy-denken-%C3%BCber-komplexe-mathematische-zeichen.html
https://de.123rf.com/photo_30762132_sch%C3%B6ne-junge-schulm%C3%A4dchen-denken-%C3%BCber-komplexe-mathematische-zeichen.html
https://de.123rf.com/photo_19124410_sch%C3%B6ne-junge-schulm%C3%A4dchen-denken-%C3%BCber-komplexe-mathematische-zeichen.html
Its a long time since the artist went to school and learned math.
