I am making something wrong? Are only 3 differential equations...
But using laplace command this system of differential eq can be solved:
See MCP9 file attached.
It may be because of the dependency of the three function in equation #2
This works (derivatives of vc1 equals derivative of vc3:
v.C3(0) cannot be chosen freely!
The situation of your circuit is impossible.
To the left of the switch, at t=-0 you have a capacitor C3 charged to 5.7 V, in parallel to the series connection of a diode, that you model with a (constant) voltage source of 0.6 V, and a capacitor C1.
This means that the voltage across C1 must be 5.7-0.6=5.1 V, not the 0 V that you set it.
As in your suggested case:
This means that in this case voltage at t=0 for C3 to be 5.7V but also we need to force that voltage at t=0 for C1 to be 5V.
But in this case:
We could let voltage at t=0 for C3 to be 5.7V, but also we could let that voltage at t=0 for C1 to be 0V.
What do you think, what is the good approach?
For my and my checking it seems that the variant with laplace is ok, but then this means that solve command cannot solve such a system of diff eq while laplace can
Your second equation clearly states that v3(t)=v1(t)+VD.
Given that VD is constant and not dependent on t this means that you can't demand an independent initial condition v3(0)=... because v3(0) must equal v1(0)+vD as in my approach above - I forgot to use "simplify so the expression looked far too complicated 😉
Your second equation also means that v3'(t)=v1'(t) and v3' can be replaced by v1' as I did.
So if your equation is correct, you just have a system with two functions to solve for. The third function v3 must be derived as shown above.
