Why the extra zeros?
MarkBuckton
Why are the extra zeros being appended to the array? Note the original function output starts 0.379m. My idea was to create a new array of values when the level gets over 1 m in height. Although I also tested to exclude zero the program block seems to ignore this restraint and append zeros to the resulting array. Why is this and can these zeros be removed because what I want is only the output values above 1 m.
Thanking you in advance.
Kind regards, Mark
Please upload a worksheet.
Mike you will find the programming block at the end of the worksheet.
Mark try this
Thanks Mike
Another MathCad trick to remember.
No problem at all Mark. I take it you understand the change.
