I have the following fairly simple equation. When I use the solve it say no solution was found but I can iteratively find a solution myself?
Having closed the worksheet and re-opened it, I did get a 'solution' to the equation but not what I expected.
I have however 'solved' it by using a Given / Find solve box
Perhaps because the symbolic solver doesn't understand units and doesn't know what a kip is?
Pleas post a worksheet (click on "Use advanced editor" at the upper right of the edit dialog)
