Wrap formula text
jdesai-2
Wrap formula text
One of my math functions/formulas is too long, and it overflows into the next page. How do I make this one line formula into a two line formula, without breaking it up mathematically.Untitled.png
6 REPLIES 6
LucMeekes
(To:jdesai-2)
Press CTRL-ENTER at the point where you want it split up. You then get a ...+ on a line below.
LucMeekes
(To:LucMeekes)
And then there is of course the more elegant notation:
That avoids the problem of too wide expressions altogether, AND keeps it on one line...
jdesai-2
(To:LucMeekes)
Thanks LucMeekes that is an excellent suggesstion. Could you please elaborate a little further, is this a vector/matrix function? Where do you get these "parenthesis" is this just shift 9..that does not seem to work
LucMeekes
(To:jdesai-2)
This is just multiplication of two vectors, one containing the numbers, the other containing the powers of y.
Type CTRL-M to specify the size of the matrix (or vector, if you specify columns as 1) you need.
There's yet another method, it's essentailly the same but elaborates the vector multiplication:LM_20171207_Wrap2.png
It saves you the part where you have to fill a vector with powers of y...
jdesai-2
(To:LucMeekes)
Untitled.pngWhat am I missing here?
Can't evaluate a function definition
