Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hi all, I use Mathcad 14.0 M020. If I integrate the function f(x)=x*ln(x) symbolic, I get the result x/2+x*ln(x) which is definitively wrong. With Mathcad 11 I get the correct result. Has anybody an idear to solve the problem? Thanks ullim
Hi Richard, thanks for your information, where can I download this update? I have a single user lizenz. I have try it from the PTC server, but there ist a support contract nesscecary. ullim
