Yet another Find issue
JasonC
Hi, I'm trying to practice using the Find function, and using a workaround with units.
Pls. see attached. The units are working but the answer it found is wrong. "Io" is supposed to be 4.
7 REPLIES 7
VladimirN
(To:JasonC)
And what about the solutions without units in Mathcad 15, suit you?
VladimirN
(To:JasonC)
And here is solution with units in Mathcad Prime 3.1:
Can't explain why , but I can add more confusion :
The attached seems to work.
Andy
lturek
(To:JasonC)
Some more fun:
1) Change the guess from 1V to 1 kV and watch the solution
2) Change the guess back to 1 V and change the V in Find() to kV and watch Io
3) Don't change the kV and replace the "ohm" in Find() by the upper case greek letter Omega (W followed by Crtr-G) and watch Io to change to 4
RichardJ
(To:lturek)
Changing ohm to capital omega makes no difference when I try it (MC15 M030).
VladimirN
(To:RichardJ)
The same result in F000 and M030 service releases.
VladimirN
(To:lturek)
In which service release of Mathcad did you play these tricks?
