check if variable is defined
ptc-4652907
my problem sounds rather simple but still I do not a have a solution in Mathcad. In order to automate my Mathcad 14 sheets I would like to check if a variable is defined or not.
If the variable is defined (not red colored in Mathcad) this on should be used instead of an different.
Holger
7 REPLIES 7
Richard's post may be helpful.
http://communities.ptc.com/message/128347#128347
Andy
Hi Holger,
I was not able to view Richard's solution, since I cannot open .mcd files, only .mcdx. I was wondering if you could possible provide a screenshot of the solution?
RichardJ
(To:thilgendorf)
The solution is a hack job using scripted components to trap the error. Scripted components are not available in Prime though, so the solution does not apply. There is no way to trap an undefined variable error in Prime and handle it gracefully. Why do you need to do this though? The original poster wanted this because they were calling worksheets from other software via the automation interface. In MC14 (and MC15) there is then a very good reason why you would want to check whether or not a variable is defined, but in Prime it is not necessary to do so.
Hi Tyler,
Please find the contents of the Mathcad worksheet in attachment in PDF and XPS file formats and on screenshots below:
LucMeekes
(To:thilgendorf)
You wrote originally "In order to automate my Mathcad 14 sheets I would like..." So why can't you open .mcd files?
Luc,
The very first post in this thread belongs to Holger, not Tyler.
LucMeekes
(To:VladimirN)
You're right. Confusion on my part.
