confrac,matrix function.
lvl107
20-Turquoise
Hello, Everyone.
Sorry, but can you explain please whats the point of this:
Thanks in advance for your time and help.
Best Regards.
5 REPLIES 5
(To:lvl107)
Are you mirroring my question there http://communities.ptc.com/docs/DOC-3496 ?
What's the problem with this? You've used continued fractions yourself quite a lot in the past.
lvl107
20-Turquoise
(To:Werner_E)
Thanks for your response, Werner.
Best Regards.
(To:lvl107)
Mathcad does not look HOW you have written your LHS expression and tries to make an as simplified continued fraction (smallest possible power of x) as possible, I think.
lvl107
20-Turquoise
(To:Werner_E)
In this case, the output looks rightly:
Best Regards.
(To:lvl107)
The other is right, too 😉
In your last example there seems to be no simpler representation as continued fraction.
Replace the "1+" in the denominator by "1-x+" (thats similar to your first example) and see what happens.
The left column in the resulting matrix never should contain a variable in a correct simplified continued fraction, I guess.
Lokk at that simplified example. In the second expression you would have expected a 2x2 mtraix with 1-x in the lower left.
