conversion Mathcad 15 to Mathcad prime 9 error
vnadot102
After Mathcad 15 worksheet conversion into Mathcad Prime 9 I'm getting an error:
Please help. Mathcad 15 did not produce an error on those matrix division.
(To:vnadot102)
Best guess is that in MC15 in the Worksheet Options the option 0/0=0 is checked.
As far as I am aware there is no comparable option in Prime.
A possible workaround could be a small utility function which is called vectorized:
If thats not the cause of problem you would have to send the MC15 sheet and maybe also the Prime sheet.
(To:vnadot102)
