Hi
The copy paste function is not working when I am trying to paste in word document, as I am using Student license any suggestion to copy the material.
Its not because you are using a student license.
PTC simply implemented copy and paste in a quite stupid way. You can only c&p single regions and you cant copy Prime regions to Word as an object (so that on double clicking the embedded objects in Word open Prime).
So you have to resort to printing to a pdf and copy from there as ttokoro suggested or use a screen capture program like the free Snipping tool in Windows (or its replacement which you access with WIN-Shift-S) or a commercial solution like SnagIt.
Copy only 1 equation to Word.
Or copy PDF page to Word.
