corrupted files.
KarstenJ
corrupted files.
Hi I am student and some of my files are corrupted.
I have 2 mcdx files where there is an error with precision in some calculations.
when the files where saved, a critical error had occurred setting precision to "" (ergo nothing) I remember ignoring it and thinking nothing of it.
I have tried a fix where you turn the files into .zip and alter the worksheet file manually, but when I try to open it after I have repacked it and changed it back to mcdx, it just doesn't open.
if anyone has a fix, that be awesome
thanks in advance.
regards Karsten
(To:KarstenJ)
rename the corrupt files to *.zip
In the zip file edit the file \mathcad\worksheet.xml by replacing every occurrence (there are a couple of them) of
precision=""
by
precision="0"
(or whatever precision you think is appropriate) and resave the edited file back to the zip archive.
Rename the zip-file back to *.mcdx and Prime will open the file.
As far as I understand, that's exactly what you were trying to do anyway. Maybe you missed to replace one or the other occurrence of precision = "".
Find attached the two modified files.
(To:KarstenJ)
precision=""
by
precision="0"
KarstenJ
(To:Werner_E)
thank you for your help.
ttokoro
(To:KarstenJ)
Collect Prime7 files attached. Yellow color equations are added.
