cot(x) + e^(x - pi) Finding another solution ?
lvl107
20-Turquoise
Hello.
Thanks in advance.
(To:lvl107)
There is always a root near every integer multiple of pi and the root is always a tiny bit smaller.
If you go further higher up to the right, then "root" will not be able to find that root because of numerical limits.
(To:lvl107)
(To:Werner_E)
You may also talk uncle Wolfram into calculating the results within a given range:
lvl107
20-Turquoise
(To:Werner_E)
Many thanks for your time and help, Werner.Smiley HappySmiley HappySmiley Happy Following up your hints I get:
1.PNG2.PNG2a.PNG2b.PNGBest Regards.
