creating a nested array
TG_8255675
7-Bedrock
I would like to write a program to create a nested array. I have a column vector containing angle values. I want to iterate through this vector and create an array of arrays with each element being [cos(angle) sin(angle)]. I am sure this is not difficult, but the syntax is not clear to me at present. I think I have been writing python programs for too long.
Thanks in advance for any help
Written in Mathcad 10, but it should work in Mathcad 11.  Just use a direct matrix form to create your nested array pair.   If you want an indexed or programmed version, that's not a problem, but this is possibly the most "Mathcaddy" way of doing it.
You might find it easier to work with the nested column vector form, depending upon your algorithm.
Stuart
6 REPLIES 6
Do you want to create an array where each single value is nested? Or, say, an array of vectors containing the sines in a single vector, the cosines, etc? Or a nested vector containing the trig values for each element of the original vector?  Or …?
Out of interest, why do you need to create a nested array rather than a flst matrix?
(Oh, and what version of Mathcad are you using?)
I am using Prime11. Basically I am trying to create a list of lists.
I have a vector comprised of angular values for an element in a machine I am designing. For each angular value in this vector, I want to create another vector where each piecewise element is a 1x1 vector like this: [cos(angle) sin(angle)]. Each element is a unit vector that I will use in subsequent calculations for dot products with other similarly constructed elements. Hoping this makes sense and I appreciate you taking an interest.
Stuart
Fantastic. Thank you very much.
No worries.
(To:TG_8255675)
Here's an alternative approach using a utility function and vectorization:
If you more like programming, you can use a for-loop, which basically is the very same what Stuart had achieved using a range variable.
