csort, rsort - why???
RadovanOmorjan
Could someone, please explain this to me. I really do not understand this behavior.
Radovan
I found the reason from the Mathcad help. It is due to the unstable heapsort procudure applied. Is there any chance to replace this procedure?
Radovan
>Regards,
>Radovan
Same in Mathcad 14.
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
>Regards,
>Radovan
GIGO.
Procedurally, a bug, but since you've commanded it to sort pathological data, anything it outputs is mathematically correct, since the algorithm doesn't care about data in any other row or column, as the case may be.
Procedurally, if the algorithm is presented with pathological data, it should do nothing, but it attempts to sort and gets what it gets.
TTFN,
Eden
