definition of a function after finding it
jzy
hey lads, attached is my picture again. I cant post the sheet due to certain calculations. And my main problem is that I am using global assignment for definition as I needed to show a summary of checks from the back of the sheet at the front page.
My main problem is if I could global assign the angle that I used the FIND function to calculate. The blue highlighted area are the parts where I have to manually input the angle. I want to global assign so that the next user does not need to manually insert the angle.
LucMeekes
(To:jzy)
It is possible, but then more items need to be defined globally. Here it is:
Now, with lambda globally defined, you can use it anywhere on the sheet.
LucMeekes
(To:jzy)
