entering data from matcad to excel componant
muhammadsarfraz
I did some calculations in matchcad and the results are in the form of 3 range variables or 3 single column matrics. I tried to bring these results to the excel component so that if I make a change in matchcad the results in excel component should be updated. however, when I specify the input variable in excel, it only picks the first value from the in put variable and ignores the rest of the column. could any one help me sort this out?
regards
Can you post your file?
Preston
Many thanks for prompt response. here is the file. at the end of the file you will see four results columns which I want to put in excel columns. cheers
On 4/23/2010 10:19:23 AM, muhammadsarfrazali wrote:
>Hi,
>... however, when I
>column
This isn't your only problem. Hopefully, the attached will help.
stv
