could you write script float to int
Sorry,
GAZ, MAZ, ZIL etc - it is cars!
What do you want to calculate?
No script needed, use ceil() or floor() function depending on whether you you want the smallest larger or the largest smaller integer respectively.
Success1
Or just use the round() function, which will round up or down according to the generally accepted rules.
We would have to use "Round" (capital R) because of the units.
True. Actually also the case for Ceil and Floor.
Do you really want to round up the result an assign Np an integer value or would you rather simply want the result to be DISPLAYED as an integer?
In the latter case you may resort to the Math formatting ribbon and select the appropriate Display precison.
