Hello All,
Could anybody help me with this question please?
I have a matrix "M" with five elements. I want to generate 10 (for example) matrices such that each element is randomly within +/- %5 of the corresponding element of the matrix "M".
Thank you in advance
PAYMAN RAJAI wrote:
Hello All,
You may use something like this for a single value or matrix
You may also turn this procedure in a function
and use this function to create ten sets using a range variable
Thank you very much Fred.
I can't open the file. Would you please send the file in Mathcad15?
PAYMAN RAJAI wrote:
Hello All,
Nice and Simple, Werner! The hallmark of a Good Worksheet 🙂
I'm too lazy to type out the range variable, though ...
Stuart
Thank you very much Werenr and Stuart. A great help
