Dear PTC experts, i would like to ask your invaluable pertinent to the attached file. In this problem, i am evaluating Zpq for a frequency (f:=2.45*10^9), the value of Zpq turns out to be complex and i have seperated the real and imaginary parts. I would further like to evaluate Zpq for a frequency range i.e., from 2.2*10^9-2.6*10^9 with step size of 0.5*10^9. Moreover, i would like to plot Zpq against the mentioned frequency range. Any help in this regard would be highly appreciated. Many thanks
Your desired step (0.5GHz) is already larger than the span (2.2 to 2.6 GHz), I assume you meant to have a step of 0.05 GHz.
Anyway. What you have to do is:
1. Define Zpq as a function of omega.
2. Define omega as a range, and then request evaluation of Zpq(omega) to get a table
3. Insert an XY plot and enter omega as the x-axis varable, and Re(Zpq(omega)) {and Im(Zpq(omega))} as the y-axis variable{s}.
See attached.
PS. I'm not a 'PTC expert'. There's little I know of the company, and I don't think it is beneficial to share my ideas about that company.
I will settle for 'Mathcad expert' though. ![]()
See attached.
Dear LucMeekes,
I am deeply grateful for your kind help and yes out of desperation to reach out for help, i mentioned PTC expert than Mathcad expert. Also, inadvertently, i mentioned the wrong step size, thank you for correcting, it is indeed a step size of 0.05 GHz. I cannot open the attached file because i am using the version PTC Mathcad prime 3.0. May i know which version is required to open the attached file? Thank you very much for your time and effort.
It's version 3.1. In its (in?)finite wisdom PTC has decided that Prime 3 cannot open Prime 3.1 files.
Apparently you're using a full version of Prime 3. I'm using an express version of Prime 3.1 which you could also install, but I'm afraid it might render your Prime 3 lost. So I would advise agfainst trying that.
So I'll show you in pictures what I've done, so you can rebuild it in Prime 3.0.
Her goes:
Add (omega) to definition and all evaluations of Zpq.
Note that I get errors for the Re() and Im() functions because Prime Express considers them 'advanced' functions, too good to freely give away.
And here's the definition of omega as a range.
The definition of a range is: <first value>,<second value>..<end value>
You enter it as e.g. 2.2,2.25;2.6 to get 2.2, 2.25..2.6, then add the other multiplications to it.
Again I get an error message, due to the use of the Re() function.
This is my plot of the absolute values (vector length) of the complex numbers:
Luc.
If you do run in trouble trying to duplicate the above, don't hesitate to post your file.
I (and many more frequenters of this forum) can open it.
Dear Luc Meekes,
Thank you very much for the kind help. It solved my problem, with your detailed guidance, I was able to duplicate it perfectly.
Good day shabby sam
I am glad you were able to find a solution!
Would you please mark Luc's answer correct as it make the information easier for others to find.
Thank you!
Toby
