help with plotting piecewise function
rb3
3-Newcomer
3-Newcomer
Hi, can someone help me, I cannot figure out what I am doing wrong in this.  The error I get is that the value must be a scalar.
terryhendicott
(To:rb3)
Here is chart using the Chart Component of Prime5
6 REPLIES 6
terryhendicott
(To:rb3)
Because you have not included the Prime sheet I have expressed the function in terms of all the input values.
Not sure if you are using Prime 15 or 14?
In your sheet T is a range variable so the comparison with a single variable T0 cannot be done.
Cheers
Terry
Hi Terry,  I'm using Prime 5 and I'm ultimately trying to plot the piecewise function that I was attempting to define with the code posted.  I made those changes, but it still is not working.  T0 is a single value, where T is an array, I tried a while loop to populate Sa but I could not get that to work either.  I'm just trying to populate Sa with values and then plot Sa and T.
terryhendicott
(To:rb3)
Hi
Here is the plot with some values assigned to the variables.  T is a vector of values.
terryhendicott
(To:rb3)
Wow! You sure are far ahead of your time 🙂
terryhendicott
(To:rb3)
Forgot you also need to include what happens when T is equal to the comparison boundary limits.
Here is one way.
Cheers
