how can I write "otherwise" in mathCAD prime 3
Prime uses "else" instead of the "otherwise" used in Mathcad 15 and previous versions.
Either pick else from the Programming toolbar or type else into a placeholder then type ctl-J (ctl-J converts typed programming keywords into the equivalent Mathcad programming symbols - one of Prime's nicer new features)
Stuart
Stuart
