how to change populate a combo box value based on another combo box and table.
EP_10996709
8-Gravel
working with Prime 10.  I have two lists with different type of tubular threads.  Using the first combo box select between the two list to pull data from.  Automatically populating the second combo box with available tubing size.  Then auto populated the next combo box with available weights.  If not with a combo box can this be done with a list box?  Pulling from a data table and not having to load all the data within a script editor?
Combo box is a basic control with no opportunity to script how the combo box operates.
List Box is an advanced control that can be scripted to change given a response.
Cheers
Terry
Thanks Terry.
I have reviewed this demo several times and it all good.  But what I am looking for is something similar but with a combo box.
We have a Database with several hundred different size and weight for thread connections.  within a combo box if I pick 3 1/2 size the next combo box list available thread weight for the 3 1/2 connection.  This data then can be used to do several calculations withing Mathcad.
Thanks Ed.
Cheers
Terry
Hi @EP_10996709,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
