I would like to return vector values to scalar ones. How do I do this?
Example:
I would like the above matrix returned without units.
Thanks in advance for the help.
Stripping units can be dangerous. One way is the "UnitsOf()" function
Note that if you specify your variables in non-standard units, the values will be adjusted:
Turning a vector (or list of values) into a scalar requires a better understanding of what the application is.
