statespace solver: A & B matrix must be functions (of t)
JBlackhole
To all,
Made some minor progress in understanding & using the statespace solver.
As my test case is a 2-dofs system I think I have established the matrices required by the solver.
However the solver needs/wants the A & B matrices to be functions (of time in my case) but cannot set it up correctly (see attached). I did find an old thread on a similar issue but cannot open the file
Any suggestion on the correct syntax?
Regards
u(t)  must be a 2x1 vector.
A(t) has C and K the wrong way round.
See attached for corrections.
Alan
6 REPLIES 6
-MFra-
(To:JBlackhole)
Hi JB,
But A (t) does not seem to be correctly defined. You should correct it:
thanks
Alan
u(t): forgot about that
not sure I understand the K and C being inverted in the A matrix as it seems to correspond to the notes
-MFra-
(To:JBlackhole)
The Shannon sampling theorem says that the sampling frequency of a time signal, must be equal to or greater than two times the frequency band of the given signal.
Moreover something is wrong with the index i:
not sure why I cannot convert the predicted solution (using the ODE) inot a sampled vector to be used in the FFT
look like MC doesn't like starting the sampling at i=0. Starting at 1 seems to be OK eventough I get a flat FFT!
