how to tan^2
mdewolff-2
2-Explorer
how to tan^2
I want to calculate dynamic deflection of the worm in a worm drive. The formula given in my book does not seem to work in Mathcad Prime 3.0.
In the book there is no multiplier (*) printed after tan^2 and cos^2. There is just empty space. I did change the formula around in all kinds of ways.
I put tan inside parenthesis like (tan)^2, or (tan^2*(gamma+Q)), or (tan(gamma+Q)^2) but nothing works.
What do I do wrong?
Thanks maurits
tan²(x) = tan(x)²
You have to use the second format in Mathcad.
tan²(x) = tan(x)²
mdewolff-2
2-Explorer
(To:MJG)
Thanks! That worked.
(To:mdewolff-2)
If you would like to match the notation in your book you could first define
and then use this newly defined function
Note that the first exponent 2 in the function definition is not an exponentiation sign type by ^2 but rather the small superscript available from the keyboard (on mine via altgr+2).
