Hope you guys can help.
I can print out the range multiplied by some value:
Why can't I store the resulting range in the variable?
Add tu as a subscript to tv by typing tv[tu.
Because a range is an implicit loop, not an a array of values. Use a vector instead of a range.
Further to Werners suggestion, see below.
I have used an undocumented feature to turn tu from a range to a vector by in-line evaluation.
Mike,
What version of Mathcad is that? My 15 M030 won't do that.
Fred Kohlhepp wrote:
Mike,
This undocumented feature exists since inline evaluation was intruduced.
I am using the same version as yours and it works OK, although I get different display of the inline eval than Mike:
Dang!!
Learn something every day! Neat!
Dang!!
And it's a Friday ![]()
This feature is useful when the range is small and can be evaluated.
Mike,
I think it has something to do with the display option settings.
Double left click, look under display options tab. I have the 'matrix display style' set to Matrix. I believe yours will be set as Automatic?
Mike,
Yes is has. The way the result is displayed depends on the global display settings (which are "automatic" as you correctly guessed) and cannot be changed for that region alone. Thats one of a few mysteries of the inline eval.
Mike,
I am using M030 Fred.
Thanks for your answers, guys.
I am using subsript feature suggested by Mike Armstrong, but it still does not work:
LiL is still one thing that keeps formula from being computed.
Please upload the worksheet again.
Not a picture ,the worksheet. You can do this by clicking 'use advanced editor'.
a few comments:
1. the range K is specified so that it returns a 1 element range K = 0.1 (is this what you meant?)
If you only use start & end on the range , I think, mathcad assumes a step size of 1
2.either add the iL range to the Qe variable or remove it from the L .
Mathcad can do either.
3.when you ask mathcad to multiply two variables dependant on the same range variable , it can assume that the result should be vectorised ( the same calculation repeated for each step of the range variable.
if, as here you have 2 independant range variables mathcad cannot decide what you want and reports an error.
If it should give a 2 D matrix as the result , then you will need to write this explicitly.
If you want each step to calculate , incrementing the value of , both iL and K, then K needs to be created with an equation based on iL.
Mathcad cannot combine ranges of different lengths
Andy
Have a look in the attached worksheet. There is a user defined function called vec which accepts ranges, range variables and converts them into a vector. Use this instead of using ranges.
Remember you may have to explicitly vectorize using this method.
Sorry am too busy to work through it at the moment.
greg re wrote:
Thanks for the tip.
You are replying to your own post, so its not clear what tip you mean.
Why are you still using a lot of ranges when is was already said a couple of times here that you should use vectors?
You are defining some ranges in a way which shows that it seems to be not clear to you what a range is and how range definitions work.
1) K:=0.1 .. 0.15 what do you think that this definition is creating? It will create just a range with a single value.
2) G1:=50 .. 10^(-1) Again, what did you expect to get? You again do not specify a step width by providing the second value, so you get a range from 50 to 1 with step 1.
What do you expect to get when you calculate G? This expression is (mongst others) dependent on 2 variables L and K, which you defined as ranges. What do you expect that G would look like? If you excpect a 2D table you would have to explicitely create it, as Andy already pointed out.
Keep in mind that a range is not a data structure consisting of a couple of values like a vector. You can look at a range as being an iterator, an implicit loop. So you should use ranges in three situations only:
- to index vectors and matrices
- in aprogramming conntext to define a loop
- as abscissa value in a 2D plot
For further information please read on here: http://communities.ptc.com/docs/DOC-6073
