integration of data points?
JBlackhole
To all
Given a set a data points, is it possible to get the ara under the curve defined by these points and the X axis? Attached a "4-point" example
JXB
FDS
(To:JBlackhole)
Dear Jocelyn,
See attached,
Filip
JBlackhole
(To:FDS)
Filip
Thanks for that. Neat and simple. Will give it a go with all the data points
JXB
RichardJ
(To:JBlackhole)
From the data analysis handbook.
thanks for that
