Hi folks,
I lookig for a list box component or something similar for which I can make multiple selections in one shot (for instance, by presing the ctrl button as in excel).
Thanks a lot for your help
Best Regards,
-JM
May be so:
There is a multiselect list box here:
Search for "Dynamically filled list boxes"
Thx for your answer Richard.
Does it work out properly for you?
For me, component not really reliable.
Also, do you know a way to change the size of the box?
Auto-adjustment ?
thx anyway
-jm
In what way?
Auto-adjustment ?
I can add seom inputs so that you can easily change the height and width. Autosizing is not available though.
1) By reliable, I meant that if I press left click + crtl once on the first item, the third and finally the fifth, it will select everything or unselect my initial selection.
++> Same observation with other scenarii.
2) I tried to add arguments like MSlistbox.Height = 11 etc... at the beginning of the script but seems not working!!
Thx for your help on both items
JM
1) By reliable, I meant that if I press left click + crtl once on the first item, the third and finally the fifth, it will select everything or unselect my initial selection. ++> Same observation with other scenarii.
Hmmm. Works fine for me. If I select 1, 3, and 5 then that's what I see in the output vector. Which OS are you using?
Not something fancy ... just XP!
May I ask you to help me to resize the listbox, please?
Thx Richard for your valuable support
Best regards,
-JM
Well, when I tried I can't get anything to work. The ListWidth and ColumnWidths properties will not do it. If I increase them I just get a horizontal scrollbar ![]()
You can get a resizing box, but it's painful. Left click the mouse repeatedly on the bottom edge of the box, just above "ListBoxOptions". If you do that enough, while moving the mouse slightly, the resizing box should eventually appear.
Not fully understand why this cannot be scripted!
Should be supported by VBA right!!!
I really like Mathcad but sometimes is a pain (especially scripting components)!
-JM
