please try to find solusion of the problem in attachament. Please solve it for coefficients A B C f v = 1. I tried write the matrix but i've could not. Please help write correct matrix for my problem and then solve linear it. The matrix i the importantiest
Thanks for help.It was wery helpfull for me. But this is only 1 problem. We need it resume with the neuton-rapson method. I need only sample for it.
Couple things:
Mathcad considers that array and matrix indexes start at 0 by default. You change this with the system variable ORIGIN.
The order you do things makes a difference. I've put in a small example (3 by 3 instead of 440 by 440) to demonstrate:
I think for matrix K you intend to assemble as one large matrix, but you have made a nested matrix.
This shows how you assemble a larger matrix from four smaller ones.
Cheers
Terry
By chance, is the K11 matrix tridiagonal? that is:
Are you looking for Newton-Raphson in several variables algorithm? see attached.
Thanks for this informaction we will back to this nxt time.I ve done it but i am not sure if i did it correctly, would you like looking it in attachment?
Great job. Thanks. How we can write separately u and v? then see a graph in 2d for i and j parameters?
I do not know the various steps you did to get the matrix that I renamed MK, so I do not know how to proceed. u and v?
Look at the equation. we have u and v dimensions. Results is for both dimensions. We need to divide it on down matrix u and v. Then we need to show results on graphs.
I could hazard this solution ..... but it is completely heuristic ....
Hello, wow, great job. Would you compare solution in two case. For me is not the same. Is possibility draw a graph u,v in 3d?
Hej. Thanks for solusions. Would you like preparining a situaction when we have orgin=1. This will be the best situaction. I going to prepare real seample and then I will show you it.
Hi, I am from Poland, I've been writing PhD and I have some problems with the finite.... I need to take your solisions and think how it write with real coefficients. I going to write it and we will think about it.ok?
Ok!
Hi. I could not have solved my problem. In attachment you will find a sample of shield. I discretizationed it and for it we have model of finite difference method the same like last time. for point 3 - u,v=0 for point 28 - u,v=0. For point 5,10,15,20,25 - right site of equation is 10. Please help.
Please be clearer. You should consider the fact that I am not aware of the physical system related to the differential equations that you have published, so I do not know how to help you.
ok. i will write some. I need only help in mathcad I can write what we need to do in Word.
I ve done some. I do not know why i have 74 x74=K we need 72x72 and order are the same like in sample. positions 36 of v are ok. this means 36 u and 36 v from beginning 1,i and i,1
You've set N:=72, and you let j run from Origin to N+Origin (that's up to N+Origin=72+1=73).
Then you index MK up to j+1. That makes 73+1 =74 maximum.
Hi. I ve done some but I need to do stresses and I do not know how to take into account boundary conditions. Solution is without it.
