motion and torque
GKing-disabled
motion and torque
Problem 1
a person stands on a platform 10 meters high, and throws an object at 14 m/s at 45 degrees.
1. how high did the object go?
2. how long did it travel in the air?
3. how far did it travel?
Problem 2
disk A has a moment of inertia of 6
disk B has moment of inertia of 1.5
angular velocity of disk A is 1.0
1. find the angular velocity of both disk together
2. find kinetic energy of A and B separately
3. what difference cause changes in kinetic energy and angular velocity
On 7/14/2009 8:40:03 PM, GKing wrote:
>Problem 1
>degrees.
>the air?
>Problem 2
>of 6
>of 1.5
>1.0
>and B separately
>angular velocity
We're not going to do your homework for you. You need to make an attempt, here.
TTFN,
Eden
