ode resolve
joyeuxp-disable
ode resolve
hello, i am new mathcad users and i need your help
I'd like to solve a differential equations system, but in Reset-up from time to time the initial conditions. for example we have a movement with mechanical stops, I must be checked each time step the position and I'd like to reset my differential equations for preventing the movement. I find this problem also for calculating eddy currents in axisymetric but I ran into a problem of computing because the solution can become complex when the penetration depth becomes zero which sets the calclul
can you help me with different exemple
thank you in advance
The work sheet would help.
If you have it in french OK too,
but "save as" version 11.
jmG
voici mon probleme mecanique et de courant induit, je m'y prend peut etre mal merci de votre aide
>votre aide
_______________________________
Visiter:
http://collab.mathsoft.com/~Mathcad2000/read?131121,101
jmG
