odesolve problem
MilchMachtMunte
2-Explorer
odesolve problem
Hi everyone!
I'm trying to solve a simple system with two ODE's and I'm stuck. I just do not see my fault.
Any help is appreciated.
Leander
See attach please
7 REPLIES 7
See attach please
Hi
wow, thanks for the fast answer!
So it's not possible to replace the case distinction with a variable?
Leander Rankwiler wrote:
Hi
You Welcome!
Try please.
Hi
Sure it is and you did nothing wrong at all in setting up your equations.
There was only one small error in your first equation inside the solve block: There is a multiplication sign between F.s and the parameter parenthesis.
Werner
It is one way to the... Mathcad House >>>
One of your Fz(xh,xl) (in the first equation of the solve block) is not a function; it's Fs times (xh,xl)
Hello
many thanks! Perfect.
you saved my last nerve 😆
