on error- continue the calculation
payman
Hello All,
I am running my program for a few thousand cases. Unfortunately when one case has error, the program stops on that case. How can I address the program to jump over the erroneous cases and continue the calculation?
Another question: is it possible to find out about the progression, for example how many cases has been left or required time estimation?
Thank you.
Please post a worksheet.
From your description the 'onerror' function might work.
(To:payman)
You sure would have to be more precise about the nature of the "program" you are running.
In general the approach would be to protect a critical calculation which could throw an error by the "on error" command (or "try" in Prime) which could return a string or NaN in case the calculation fails. This return value them can be used in a conditional branch.
