I want to create an indexed function which is parameterized. A simple example would be: gk(w) = w+k where k a subscript index. Is there some way to do this. I have tried a few methods such as placing the index k after the function: g(w)k (again where k is an index) but this does not work.
Fritz
You can create an array of functions and call them with an index, or you could create a function of two variables.
