To all
I haven’t got a mcad 15 worksheet yet working on it while I am reading a couple of things on the matter – please bear with me and will attach soon
Is there any way of plotting a gyroid in mcad15? Looking at the ebook bout the ‘amazing picture in mathcad’ looks like it ought to be simple.
I am looking at the equation (see links below) for such shape and look straightforward but once again plotting 3D stuff in mcad is proving a pain.
0=sin(x)*cos(y)+sin(y)*cos(z)+sin(z)*cos(x)
Is anyone able to point me in the right direction?
@ttokoro is must be your kind of things
https://soulofmathematics.com/index.php/gyroid/
https://plus.maths.org/content/meet-gyroid
You may give the implicitplot3d function from Viacheslav N. Mezentsev a try
https://community.ptc.com/t5/PTC-Mathcad/implicit-surface/m-p/81041/highlight/true#M31975
https://community.ptc.com/t5/PTC-Mathcad/CreateMesh/m-p/97285/highlight/true#M38466
https://community.ptc.com/t5/PTC-Mathcad/Question-on-Implicit3d/m-p/9849/highlight/true#M3736
thanks a lot. Quite something
did a test by replacing the (fx,y,z) function and got something (a=1)
Clearly nothing built-in so won't look deeper into it. Will use MathLab as there is a implicitplot3d capability
Prime 7 3D plot is limited to 40,000 points.
40,000*2 plots.
