programming a function whose result is a function
ptc-4507537
7-Bedrock
Hi...
Can someone tell my why I can't programm a function whose result is a function? Or show me a solution?
I have attach a file with the problem.
Thank you...
Thank you for your help. the solution of Alan ist good.
Regards
Oliver
10 REPLIES 10
No file attached.
Mike
It looks to me like you're trying to do symbolic math. While mathcad has a symbolic processor it's weak and buggy compared to some others.
That said, you can do what you want, just not in a program.
(To:ptc-4507537)
Something like the attached?
Next time please include a Mathcad file, not only a screenshot.
WE
I believe he was meant to attached the worksheet, not just a screenshot.
Mike
Please attach your Mathcad worksheet to the message.
Thank you for your suggestions
I must constantly transform a polygon (s-Domain) in a normal form. For this I need a symbolic function that I can call always.
I think that Mathcad can' t access a vector in a defined function.
I attach my Mathcad worksheet to my message
Does the attached help any?
Alan
Edited: Slightly improved file.
I can get some of the way to understanding what MathCad is doing, but there are a number of issues that don't make sense.
1. Changing N & D to N(x) & D(x) in the std definition stops it working,
2. Calculating Z.3(0) fails but creating a function y with the substitution works ??
I must be missing something obvious...
Hopefully the attached helps but I would appreciate knowing the final outcome (if it works)
Regards
Andy
Here's a vectorised version.
Alan
Regards
Oliver
