Hi there.
I am planning to put all the formula in the matrix format. The output I wanted is, I want to see first the formula before the numerical answer. I am trying to use the symbolic evaluation but I am not getting the result I wanted. I need some help if this is possible.
When using symbolic eval, did you use "explicit, ALL" ?
Yes . Actually this is the result. I attached the file for your reference.
Hi Werner.
All the variable have an equivalent constant value that was assigned. The text I want to see is the formula assigned in the matrix index. Is this possible ?
Lex Dante wrote:
Hi Werner.
I don't think so ![]()
