Hi. I have the problem presented in the attachement. I need to replace the value of the determinant of the second expression with B, to make it simpler. I've tried with "explicit, B" but it doesen't work. How do i do that? Thank you
Here is the whole content of his file:
He has alreaday asked the same question here: http://communities.ptc.com/message/261653#261653
For reasons unknown to us he wants Mathcad to display something like
which I guess is demanding too much.
Can't see your file at the moment but the mathematical term for replacement is substitution. Mathcad has that built in. Use the 'substitute' symbolic keyword with argument {determinant}=B.
It is possible, if you tell Mathcad what you want it to give you. With:
Yes, thats basically the way I did it in the file I posted. Not sure if it had helped.
Ok. I understood so the first thing i want to know is how do I insert that bold equal sign. Sorry but i'm a dummy ![]()
This boolean equal sign is accessible from at least two palettes ("calculator" and "boolean"). I usually use the keyboard shortcut Ctrl & +, but this may be different, depending on the keyboard layout you use - I am using a keyboard with German layout.
Thank you very much.
