solve/Find() with diffent cosntant
JBlackhole
To all
I am sure I have seen queries about a similar problem but cannot find anything. I am looking at solving a set of 2 linear equations, see attached, using the Find() option, but I want to do it a number of time as I want to change some of the cosntant.
JXB
10 REPLIES 10
Create a function of the constant (variable) you want to change
Further to Fred's example, a vector of values can be passed once solve block is passed as a function.
Mike
Thanks to Fred and Mike for the solutions. I am now half-way of implementing, see snapshot attached, what I am after. Will need to vectorize each function so that I can implement a neater solution and plot them next to each other and not on top of each other (ie graph for step 2 start at the end of step 1, etc)
Regards
JXB
Can you please post the Mathcad worksheet, clearly indicating what you want.
Mike
Mike,
will do so as soon as I have a/ clean the worksheet b/ I have go the time as I am developing this worksheet on the side ie when I have go the time as real work as to take priority.
JXB
JXB
Yes, that thing called work always gets in the way of fun
Mike
Mike
here it is 1st pass. not pretty but seems to work OK. I am ignoring units at the moment
JXB
I'm a little lost. What are you trying to do now The worksheet seems ok, to me anyway.
Mike
Mike
Well it does something!! I just posted it for "completness" really. I guess I'll close the query
JXB
As long as you have your answer.
Mike
