To all
I am sure I have seen queries about a similar problem but cannot find anything. I am looking at solving a set of 2 linear equations, see attached, using the Find() option, but I want to do it a number of time as I want to change some of the cosntant.
JXB
Create a function of the constant (variable) you want to change
Further to Fred's example, a vector of values can be passed once solve block is passed as a function.
Mike
Thanks to Fred and Mike for the solutions. I am now half-way of implementing, see snapshot attached, what I am after. Will need to vectorize each function so that I can implement a neater solution and plot them next to each other and not on top of each other (ie graph for step 2 start at the end of step 1, etc)
JXB
Can you please post the Mathcad worksheet, clearly indicating what you want.
Mike
Mike,
will do so as soon as I have a/ clean the worksheet b/ I have go the time as I am developing this worksheet on the side ie when I have go the time as real work as to take priority.
JXB
JXB
Yes, that thing called work always gets in the way of fun ![]()
Mike
Mike
here it is 1st pass. not pretty but seems to work OK. I am ignoring units at the moment
JXB
I'm a little lost. What are you trying to do now The worksheet seems ok, to me anyway.
Mike
Mike
Well it does something!! I just posted it for "completness" really. I guess I'll close the query
JXB
As long as you have your answer. ![]()
Mike
