time function
ValeryOchkov
time function
Is time function again built but not in the function list?
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
7 REPLIES 7
The time function is listed under Special Functions.
Mona
>Mona
OK! Thanks.
But it will be good than yhe time function returns value with time units and do not uses one argument:
time=39.617...yr
Val
On 9/10/2009 12:43:52 AM, VFO wrote:
>== But it will be good than yhe time function
argument: time=39.617...yr
Good idea, Val, but perhaps use 'Time' for this
purpose to avoid any backward compatibility
problems?
Stuart
>time=39.617...yr
>Val
>m
The reason to allow time to have a dummy argument is to force it to calclate when that argument changes value. For example,
x = 1
t0 = time(x)
y = x
t1= time(x)
This setup allows t0 and t1 to be synched to y. Without the dummy argument, t0 and t1 would only be calculated once.
Robert
IRstuff
3-Visitor
(To:radair)
Mathcad traditionally recalculates everything from the top to the visible window, regardless of whether anything changed.
TTFN,
Eden
StuartBruff
(To:IRstuff)
On 9/10/2009 3:41:31 PM, eden_mei wrote:
== Mathcad traditionally recalculates everything from the top to the visible window, regardless of whether anything changed.
I don't think so. It recalculates those things that need changing. I've often resorted (as in the worksheet in this thread) to putting a parameter in time to force it to evaluate along with changes to a variable.
Stuart
There's probably a bit of an issue here between what could be done and what is currently done as far as function updates. Currently, I think implementing time without a dummy variable would act like rnd. rnd(1) doesn't get updated each time the worksheet recalculates unless the cursor is sitting inside the function so that it appears to be modified.
I have created functions that get marked as "dirty" each time they calculate using controls, but automatic mode gets a bit of a headache trying to figure out when to stop computation. The dummy variable solves that issue, but that doesn't mean it's the only solution.
Robert
