to write an equation
gbayazid
Dear Friends,
Please help me to write an equation, which is attached.
MJG
18-Opal
18-Opal
(To:MJG)
In my opinion, these two alternatives are more clear than the equation in your image (values for a.min, a.max, and D are assumed):
6 REPLIES 6
MJG
18-Opal
18-Opal
(To:gbayazid)
It would help if you showed us the values of each variable.
To me, it looks like they used an infix operator.  In my opinion, this just makes it confusing.
Select "Infix Operator" from the "Evaluation" toolbar (View -> Toolbars -> Evaluation).
Three placeholders will appear.  Type the first variable in the first placeholder, the function (min or max) in the second placeholder, and the second variable in the third placeholder.
Example:
MJG
18-Opal
18-Opal
(To:MJG)
gbayazid
(To:MJG)
Thank you Mark Gase.
MJG
18-Opal
18-Opal
(To:gbayazid)
Not sure off hand.  Do you know what it does mathematically?
MJG
18-Opal
18-Opal
(To:gbayazid)
Is it the "vectorize" operator?  It should show as an arrow over the equation:
It's available on the "Matrix" toolbar or by pressing Ctrl -
