I am trying to iterate within a piecewise function. Specifically, I have a model for the heat release of an engine, and the second range of pressures is found through iteration. I know the initial condition. On the attached worksheet, the variable 'P_q' is the one that is found via iteration, i.e. P_q,new = f(P_q,old, etc.).
Thank you in advance for any assistance with correcting the logic in my attempt.
May by so - not functions but vectors - see pls the attach
The attached might help as far as the pressure is concerned.
Alan
Hello keena, would be acceptable this solution?
