In Prime 3.1, the xy plot shows up blank when I print to pdf. Please help.
Not only does PDF file show blank, I printed to a color printer the plot is also blank. I then changed the increment from 0.0001 to 0.001, the plot came out. I was plotting a sine curve with a range from 0 to 8*pi. Apparently too many points creates a problem when printing.
Try a different PDF printer.
More details may get more help.
