xy plot - undefined variable
dagi
Hi
My problem is to plot angular velocity as function of time. I get the message "this variable is undefined. Check that the label is set correctly" for the variable t - well - it's a variable defined in the function? -
Tips would be much appreciated.
Fred_Kohlhepp
23-Emerald I
(To:DJF)
In this instance "t" needs to have units of time to balance the equation.
DJF
(To:dagi)
Sometimes mathcad needs its plotting range defined.  Usually it will default to -10 to +10 but sometimes it doesn't.  Not sure why.  Anyway, just give it a range variable for t.
t:=0s,0.01s,1s
dagi
(To:DJF)
thanks 🙂
Fred_Kohlhepp
23-Emerald I
(To:DJF)
(To:DJF)
To be specific: You can't use the quickplot feature with units. You need to define a range for the abscissa values whenever you have to assign units to them. Keep in mind that when defining a range with units, its mandatory to provide the second value. Something like t:=0s .. 100s won't work.
