CalculateStatus does not run immediately after being called
Willie
On my asset detail page, I have a mute button (toggle) to "Disable" the asset Thing.  When this button is toggled from "OFF" to "ON", it mutes (disables) the asset Thing.
The code for this process is shown below:
try {
if (Things[SerialNumber].MuteStatus === false) {
Things[SerialNumber].MuteStatus = true;
Things[SerialNumber].MuteDate = new Date();
Things[SerialNumber].AssetStatus = 6;
Things[SerialNumber].CalculateStatus();
logger.info(me.name + ": muteAsset: isReporting: " + Things[SerialNumber].isReporting.toString() + " reportingLastChange: " + Things[SerialNumber].reportingLastChange);
logger.info(me.name + ": muteAsset: MuteStatus: " + Things[SerialNumber].MuteStatus.toString() + " AssetStatus: " + Things[SerialNumber].AssetStatus + " status: " + Things[SerialNumber].status + " isEnabled: " + Things[SerialNumber].IsEnabled());
Things[SerialNumber].DisableThing();
logger.info(me.name + ": muteAsset: isReporting: " + Things[SerialNumber].isReporting.toString() + " reportingLastChange: " + Things[SerialNumber].reportingLastChange + " isEnabled: " + Things[SerialNumber].IsEnabled());
} catch (err) {
logger.error("muteAsset: " + err.lineNumber + ": " + err);
For some reason, DisableThing( ) completes execution before CalculateStatus( ).  I need CalculateStatus( ) to complete execution before DisableThing( ), because I need it to change status to "Muted" before it gets disabled.  I know DisableThing( ) completes execution before CalculateStatus( ), because I saw in the script log that it tried to run line 7 (CaculateStaus) after the asset Thing was disabled.  Please see the screenshot below:
It seems that CalculateStatus( ) executes at least 7 seconds after the muteAsset( ) service was called.  How can I get CalculateStatus( ) to execute before DisableThing( )?
1 REPLY 1
abhkumar
(To:Willie)
HI  @Willie,
Could you please mention which OOTB services have you customized for mute status calculation and which other services of Thing Shape PTC.SCA.SCO.StatusThingShape  have you customized.
Additionally, it required to investigate  into the snippets you have written. Do you mind opening a support case for it.
Abhishek
