Connecting Thingworx Manufacturing App to OPC aggregator
I am facing an issue while connecting Thingworx Manufacturing App to KepwareServerEx5.2.
I performed below steps
1. Install OPC Aggregator
2. Install Thingworx manufacturing 8.4
3. Create a new Kepware legacy aggregator connection from Controls adviser. (entered Server name as KepEx5)
4. I got set of configuration settings which I need to configure in OPC aggregator. In these settings I find the thing name as KepEx5-GW
5. I entered these settings properly in OPC aggregator - Thingworx tab.
6. When I start the connection, event log shows connected to Thingworx using thing KepEx5-GW.
Below are issues
1. However I get error in event logs which states attempted to add "ProductName" failed.
Cannot add item "ProductName"
2. When I check under aggregator tab in thinworx controls advisor, status is unconnected. When I go to composer, I can see the thing KepEx5-GW is connected however, KepEx5 is not. How can I get the thing KepEx5 connected to OPC aggregator?
I am stuck with these issues for a while now.
Thank you.
Pawan
