Hi @hrajpal ,
I'm also facing same issue, but i couldn't find the RemoteAccessExtension in my support portal.
Is it license based? Also kindly let me know if there is any workaround.
Saran
Hi @SaranKarthick.
What procedure are you using for accessing the downloads? If you're linking to it from the Sales order, it may not show up. Try these instructions:
--Sharon
Hi @SaranKarthick.
--Sharon
