I'm looking for uninstall.exe (for uninstallation).
tikegami
Hello
> How do I uninstall the ThingWorx Manufacturing Apps?
> The ThingWorx Manufacturing Apps download includes both a setup.exe (for installation) and an uninstall.exe (for uninstallation).
The specified file is not included. I'd like to how to uninstall.
Hi Takashi,
The uninstall application should be located here:
<Install path>\ThingWorx Manufacturing Apps
Please let us know if you are still unable to locate this file.
Polina Osipova​ - In my test setup, I did not have the uninstall.exe in the downloaded zip, either. It was created in that directory above after running the install (setup.exe).
Best regards,
Steven M
6 REPLIES 6
posipova
20-Turquoise
(To:tikegami)
Could you please provide a screenshot of what your unzipped archive looks like? Should be this:
Hello.
Thanks for reply.
The source of the file is "01_install_process" attached.
The contents which unzipped this becomes "02 _ Unzipped archive" attached.
As you can see, it differs from the thawing content of the archive that received the answer.
Is the acquired file different
takashi
posipova
20-Turquoise
(To:tikegami)
Freemium might not include all of the features..
Steven Marchessault​ do you know who could assist with this if the downloadable supplied by ptc is indeed incomplete?
Hi Takashi,
Best regards,
Steven M
If you re-run the setup.exe in the downloaded zip, it will run you through the uninstaller of the application.
Milan
Hello.
Thank you for reply.
There was an uninstaller at the described address.
Uninstallation was successfully done, ManufacturingApps could be deleted.
(It is as attached image)
After uninstalling, by running setup.exe again,
Installation was successful.
Everyone, thank you for the advice.
Best Regards,
takashi
